How do i go about advancing my timing?
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i hope this is in the right section but i wanted to know how i would go about advancing my timing by 6*. once i do this should i run premium 91 octance or run the 85 octance that i am now. i'm at 8000ft elevation in laramie wyoming so i know that makes a big difference. i used to be able to leave nice black marks back home by flooring it and now i can't even chirp my tires up here. so if anyone can help me out with the timing i'd be very appreciative.
Car: 2002 Z28
https://www.thirdgen.org/newdesign/t...ngtiming.shtml
if u have any more questions, do a search first, anything and everything u will ever need to know is a search button click away
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i just read that page and it says i need a timing light, does anyone know if most auto parts stores rent them out or loan them out. i'd buy a timing light for myself but i'm a little short on cash being at college and not having a job right now. but thankx for the link.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
A place like Autozone might rent them out. They do rent a lot of tools out, so check them. If not, you can pick up a decent light for pretty cheap.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are plently of links in the "new to TBI" sticky up top on timing. It will tell you everything you need to do to set it correctly.
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
dude even though cash may be short I'm pretty sure timing lights can be got for less than $20. I think theres a wallmart special thats even cheaper. Plus don't rent it because what happens when you need to adjust it some more? or you think it may be off etc you can't check the timing without renting one again.
Oh and doing a search here is a must theres reams of info on here, weeks and weeks of reading. everythings allready been covered by someone somewhere.
good luck
good luck
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
