Fuel Pumps
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Fuel Pumps
This kit is for the Camaro/Firebird L98/TPI:
http://www.racetronix.com/product/RX.../Dcp_0930a.jpg
This kit is for the Camaro/Firebird LT1
http://www.racetronix.com/product/RX...LT1-FPKG-2.jpg
I know the L98 kit will work with a TBI application.
In the pictures, it appears that the LT1 kit has a larger outlet on the pump and larger hose/tube. Is this an illusion because it is flex tubing versus rubber?
If it is indeed a larger outlet and hose, couldn't this be adapted to a TBI application to provide more volume (provided a larger fuel line in the float/sending unit assy?
This brings up another question; is there another GM application that has a float/sending unit assy that could be substituted for the standard TBI unit?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the racetonix kits are very nice. I've installed one in a friends GTA with a 383/miniram/AFR build-up. The L98 for the forced induction, is more pump that you will need for any TBI build-up. If you max that thing out, its probably time to look at a fuelcell / external pump combo.
and why would you need to substitute the float/sending unit?
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
ahh, do the trucks have larger chassis lines?
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
So, is it an optical illusion that the LT1 pump has a bigger outlet and hose?
I can adapt if needed as far as fuel line size in the pickup float assy if the LT1 pumps do have a larger hose.
What I'm getting at is the ability to provide more volume
Car: 1990 Camaro RS
you volume is going to be limited to the smallest point in the system. If the chassis lines are no bigger than on an LO3 car, having a bigger pump outlet gets you nowhere.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
OHhhh....
why not go with a mondo external pump.
OHhhh....
Plus, like to retain some resemblance of "factory"
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
