Runs bad when Engine is Hot
Old Nov 29, 2004 | 06:30 AM
mudflap1989's Avatar
What would make my TBI motor run fine when it is cold, but when it gets hot, it runs bad?
Old Nov 29, 2004 | 06:39 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It could be several things. below a certain temp. the computer does not do any correction to the fuel, it runs off of pre-set tables. I would check your o2 sensor, to start with.
Old Nov 29, 2004 | 07:57 AM
Thanks, I was thinking that there was some kind of coolant temp sensor, that controlled something , could it be that?
Old Nov 29, 2004 | 07:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
There are things that the coolent temp sensor controls, but if the temp sensor is not working, it should have problems all the time. The fact that it works until i get hots, makes me think the temp sensor is working. If you have access to a scan tool, you can easily check the output of both the o2 sensor, and coolent temp sensor.
Old Nov 29, 2004 | 08:44 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Theres a possibility that the CTS is faulty. If there is an excess of resistance, it can cause teh computer to register the coolant temp as being less then what it actually is. Itll cause the motor to run excessivly rich.
Old Dec 3, 2004 | 11:28 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
In case your wondering, the CTS is a sensor mounted on your manifold next to the thermostat housing.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
