open end air element
Car: 1990 Pontiac Firebird, 1984 Camaro Z28
Engine: V8 305 TBI, V8 350
Transmission: AT
i was looking at putting an open end air filter on my engine and was wondering what specifications it had to be. thanks
Car: 1991 Chevy Camaro
Engine: 305 TBI
Most people just go with a 14"(wide) by 3"(tall) open element, since it's the most common. The opening/flange for the carb/TBI should be 5 1/8" (this is also the most common, and it works perfectly). You can go with a non-drop (flat on the bottom) or a drop-base (drops the filter below the mounting flange anywhere from 1/2" to 1 1/2"). Most open elements at auto parts stores or online stores will meet all of these requirements.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome aboard. You will find that this is a common mod and that there is tons of info on this site that will help you in your descision. Take a look at the stickies above for links to various in depth threads on open elements. Because I am so confident that you will find your answer I will shut this one down to reduce some redundent posts in the system. Good luck and happy modding
mdtoren
Aug 16, 2015 05:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
