454 Dies
Old Dec 3, 2004 | 03:09 PM
red450ih's Avatar
Car: 86 FBird
Engine: 173
454 Dies
My 87 454 TBI/400THM dies when when I put it into gear (D). This all started after I had to replace the distributor due to a verified bad module and pickup. No codes are showing up. Any Ideas?
Thanks,
Keith
Old Dec 3, 2004 | 03:27 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
check to see if the distributor is 90 degress off. also might want to check the timing.
Old Dec 3, 2004 | 09:46 PM
JPrevost's Avatar
Car: 91 Red Sled
Either too much timing advance or you're lean. It's one or the other. So turn your base timing down, see if that helps. Do turn it down past stock!
If it's a lean fuel condition, change your fuel filter, if that doesn't help you've got something else going on that is abnormal.
Old Dec 4, 2004 | 01:06 PM
red450ih's Avatar
Car: 86 FBird
Engine: 173
Thanks for the help. I'll was trying to check the timing but could never find the mark on the balancer with my timing light. Turns out the inertia ring has slipped and the rubber is coming out. I have a new balancer coming in the mail. I'm also working on getting a scanner as well.
Thanks again,
Keith
Old Dec 4, 2004 | 03:52 PM
JPrevost's Avatar
Car: 91 Red Sled
I ment to say DON'T turn it past the stock setting. Sorry about that, wasn't really sober so I wasn't proofing.
Gunner242
Dec 25, 2015 04:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
