1.6rr, will these specs work?
Old Dec 5, 2004 | 06:40 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Rocker Arm Ratio: 1.60
Rocker Arm Style: Full roller
Stud Size: 3/8 in.
Rocker Arm Material: Aluminum
Self-Aligning: Yes
Rocker Arm Body Style: Narrow
Rocker Arm Nut Style: Polylock
Slot Style: Long
Slot Width (in): 0.730
Maximum Spring Diameter (in): 1.625
Thanks again guys
Old Dec 5, 2004 | 12:49 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Work for what? What cam? Depending on the last question, have the heads been machined for more lift?
I've never been a fan of alum. rockers. Full roller or not.
Old Dec 5, 2004 | 01:00 PM
Damon's Avatar
If you're talking about bolting them onto a stock engine, then yes, they will work. Stock studs (pressed-in or factory screw-in type) are 3/8" diameter.
If you have heads that take screw-in studs then I always choose to upgrade to the larger 7/16" studs. Other than making sure you buy rockers to match the larger studs they are a bolt-in upgrade and really help stiffen up the rocker arm fucrum point at higher RPMs with stiffer valve springs.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Exxon Limited
Aug 9, 2015 08:13 PM
