TPS Adjustment ?
Old Dec 7, 2004 | 06:55 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
TPS Adjustment ?
If out of spec, loosen the two screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws.
Okay, so im thinking i need to adjust my TBI unit to allow more air past the blades at idle. I loosen the two screws affixing the tps, give a few turns on the idle adj screw, then rotate the tps to bring it back to ~.54v. However, in order to tighten both screws down the tps must be at its original position.
Is there something im missing here
Old Dec 7, 2004 | 07:11 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Some tps' arnt adjustable, mainly because theres no need for them to be. As long as its around .6 V or so its fine. The ecm automatically self calibrates.
Old Dec 7, 2004 | 07:22 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
i got that -- however I'd really like to see my IAC steps around 3-10 at idle (@ normal operating temp) as opposed to 40-70. This requires that I adjust my idle stop screw in -- which in turn raises the tps voltage (blades are more open) -- which in turn makes the ECM think im on the gas.
If I were to leave the tps alone and adjust the Idle stop -- I end up with a tps value of close to 3.2% -- the ecm no longer sees this as idle, and my idle speed is close to 1500rpm.
Old Dec 7, 2004 | 07:56 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I've adjusted the idle stop screw without changing anything with teh TPS. You're turning the screw too much, usually only a very slight adjustment of the screw goes a long way. That, or your fueling or timing is off far enough that you need more turns...what's your setup?
Old Dec 7, 2004 | 07:57 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Whats the raw voltage? Did you try shutting down and restarting? That will allow the ecm to recalibrate itself. I think itll recalibrate to just about any value and regard it as being closed throttle. But, if its too high itll set a code.
Old Dec 7, 2004 | 08:10 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
ok, that may be -- i was just trying out what Grumpy had suggested here . . .
For the initial butterfly opening I cut a strip of paper a 1/4" wide and set the throttle idle setting so when the paper is pulled through the butterfly opening with a minimum of effort. If it tears the paper open it up. So now the engine starts and will idle. This is a good start.
basic setup :
350 SBC .30 over, Edelbrock Performer aluminum heads, Comp Hyd. Roller Cam 218/224 112 LSA, Speed Pro Hyperutectic pistons, 10:1 CR, Edelbrock Performer intake, 2bbl TBI 1-13/16" bores w/BBC injectors @16psi, coated Edelbrock headers, 3" exhaust.
Old Dec 7, 2004 | 08:13 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
no -- I didn't try shutting down and restarting . . . I just kinda kept an eye on values as I was adjusting -- but never rebooted. I'll try that next. Thx.
Old Dec 7, 2004 | 08:19 PM
BronYrAur's Avatar
Engine: 305 TBI
That's a pretty serious setup, are you tuning your Prom? I hope so. If not what are you running for a chip? What's your base timing set at too?
Old Dec 7, 2004 | 08:27 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
yes, I'm tuning myself -- well with the help of the DIY PROM board. I gave up on Ed Wright getting the tune down after I got a little schooling in PROM burning. Currently that setup is tuned via a PROMinator Pro, TunerCat, and RT TunerPro, WinALDL and a WB02 (passenger collector).
I've never messed with the timing, 0*d is where it ran best.
Old Dec 7, 2004 | 08:44 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Id shoot for 15-20 IAC counts. There may even be some limits imposed by the stock code for how low the counts can go. You may just have the throttle open too far, hence the high idle. 3.6% tps as reported by the ALDL isnt that far off from closed position. Its probably around .8 V. Not ideal but the computer should still see it as closed throttle and it shouldnt set a code.
Old Dec 7, 2004 | 09:21 PM
BronYrAur's Avatar
Engine: 305 TBI
Cool, you got the right equipment. What is your target idle set at? Why did you want to change the screw position in the first place, did it have a bad idle?
Old Dec 7, 2004 | 09:27 PM
BronYrAur's Avatar
Engine: 305 TBI
I just looked at the .bin for my car and there's a constant in Prevost's ecu file called "TPS% threshold for idle adjustment" and stock its at 1.96% TPS, so if its registering 3.6% maybe it isn't in idle anymore if that's what that threshold means.
Old Dec 8, 2004 | 12:36 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
My first few 'Fastchips' were set at 800 for target idle. Stock for was 600 . I've found a nice median at 700.
I wanted to adjust my IAC steps down, that is why I needed to adjust the idle stop.
Original post http://www.diy-efi.org/gmecm/papers/747iac.txt
If the engine idles with a high IAC count, this IAC air is bypassing
the throttle blades, hindering the flow of fuel into the plenum. By
opening the throttle blades and reducing the IAC counts, there is a
greater volume of air drawing fuel past the throttle blades.
Old Dec 8, 2004 | 12:39 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Dim,
yep -- I was able to to adjust the idle stop screw and tps with the Key On / Engine Off. Then disconnected the battery for a moment. Hooked it back up and TPS read -0.7% @ .54v. Thx for the suggestion.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
