081 or 416 heads on my 305tbi
Old Dec 13, 2004 | 01:37 PM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
Should i get the 081 or the 416 heads to use on my 305 tbi or is there a better one i might find in my local salvage yard? i found em both.
thank you,
john
Old Dec 13, 2004 | 01:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
they have exactly the same ports. They are the same casting, only one is perimiter style, one is centerbolt.
Old Dec 13, 2004 | 03:44 PM
Car: 89 RS
my questions are answered, thank you all.
Old Dec 13, 2004 | 03:59 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Speking as someone who has done the swap you are talking about, get the 081's. I got the 416's and wish I had gotten the 081's. The 416's don't mate up nice to the intake. It will require some drilling out the four center bolt holes on the intake. It's doable but if you can get the 081 your much better off.
Old Dec 13, 2004 | 07:00 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
That depends on your intake, not everyone is going to prefer the 081s.
Old Dec 13, 2004 | 08:07 PM
azvolfan's Avatar
well that's true. I was assuming that it would be an intake of similar bolt pattern. But if the intake is also changing, then get the one that will fit it best.
Old Dec 13, 2004 | 10:07 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
does anyone know hot to modify the intake, i have a set of freshly rebuilt 416s with big valves and springs i had done up for my boat before the block cra cracked, and an edelbrock tbi intake i would like to use them.
Old Dec 13, 2004 | 11:06 PM
azvolfan's Avatar
I have 416 heads and just did the intake swap to an edelbrock intake. The usual ovaling out the 4 center bolt holes on the Edelbrock intake will not work. Don't do it!!! The plenum on the Edelbrock is a lot wider than the stock one and the center bolts can not lay back far enough to make it to the holes. What we did (this was James'[90_WS6_Formula] idea) was take a piece of screws all and cut it into about 8 inch (approx length) lengths and then screw it into the head and then bend it up to the proper angle. James actually did it with a blow torch while the 8 inch pieces were off the car. But it worked like a charm. The intake needed no boring out on the center bolt holes. I would recommend doing this to anyone who wanted to use the 416 heads and the Edelbrock intake.
Old Dec 14, 2004 | 07:52 AM
Car: 89 RS
well, i am allready running the edelbrock tbi egr intake, so i better go with the 081's then.
john
Old Dec 14, 2004 | 11:34 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
can anyone reccomend an intake that can be used with tbi either a tbi intake or with an adapter plate that will work with the 416 heads.
Old Dec 14, 2004 | 12:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
any manifold that is designed for 86 or earlier SBC's will work with the 416s.
Old Dec 14, 2004 | 01:50 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
but any specific type of manifold work better with tbi, single plane dual plane etc. that is what i meant.
Old Dec 14, 2004 | 02:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I am rather fond of single planes with and adaptor.
but I am a little bias.
Old Dec 14, 2004 | 03:43 PM
azvolfan's Avatar
Dewey aren't you running the Weiand 7525 on your RS?
Old Dec 14, 2004 | 05:11 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Yes Sir.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
