Code 32, Can I bypass the EGR???
Old Dec 15, 2004 | 02:39 PM
paul5.0's Avatar
Car: trans am 1991
Is there a way to buypass the egr both physicaly and In the computer??? If so, HOW??? I plan on keeping this TBI system but ditching the intake for a none egr one.
My code 32 started when I got dual exaust with cherry bombs. Could that have caused it???
Old Dec 15, 2004 | 02:48 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
If you can burn your own chips (only cost about 120-200$) it's the most basic thing you can do. Physically you can just make or buy a block off plate. As for your exhuast causing a light. I have heard of some EGR valves that use exhuast back pressure to hold them shut. So yeah your exhaust could cause problems.
Old Dec 16, 2004 | 11:54 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You could try getting a standard egr valve or trying a different type of valve. Some need a certain ammount of back pressure to allow them to open. I dont have any part numbers of applicable egrs that would work, though.
Old Dec 29, 2004 | 07:46 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
I'm having the same problem and have been unable to solve it so far. My LO3 came stock with a positive egr valve, so I've tried a LT1 egr valve and still no progress. Next Im going to try a negative pressure valve.
Old Jan 1, 2005 | 10:58 AM
camarowraith's Avatar
Car: 92 Camaro
Paul, The definition of a code 32 is that the computer does not see enough flow at time of egr activation. I have had this problem for years, I personally just ignore it. The only reasoning I can really find behind it is that the program in the chip is too sensitive, cause changeing components I have never seen does any help. If you get a manifold that has no EGR provision it will not effect your performance, but may be considered illegal depending where you live. It it Illigal her I would not pass visual inspection for a smog test. Unless you want to live a Service Engine Soon light every time the EGR is supposed to activate, you would need a chip burned with no EGR program.
92firebirdguy
Sep 1, 2016 07:53 AM
Formula8r89
Sep 22, 2015 04:24 PM
Racerx974
Sep 19, 2015 10:16 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
