fuel problem someone help
Old Dec 19, 2004 | 11:44 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
ok today i replaced the fuel filter in the car, did nothing else except fuel filter. Replaced it with a cheap duetsch one from autozone. Anyways when i start the car, rpms jump up and down from about 200-500 for a min then it goes up to 1000 then eventually back down to 700-800 where it always used to idle at. Also if i get on it when i first starts up right after the idling problem and get on it you can smell a really strong gas smell. Is this the result of a bad fuel filter. Or would putting in backwards (fuel filter) cause this to happen. Any help is greatly appreciated.
Josh
Old Dec 20, 2004 | 09:30 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I can't remember the symptoms of a fuel filter installed backwards, but I would definetely double-check that first before worrying about anything else.
Old Dec 20, 2004 | 09:11 PM
Car: 82 El Camino
Engine: built 355
found the problem WASNT the fuel filter. My map sensor somehow came unplugged, and found the problem after scanning it.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
