Please, a wiring clarification once and for all...
Old Dec 21, 2004 | 03:31 PM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
You would not believe how many conflicting wiring schematics I've read regarding a 454 TB going on a 350/305. It seems to me that the conflict may be partially due to what ecm you're running. I'm running a 7747 which was the same that the 7.4L trucks used. Based on that, I'm going to wire mine up A-A, B-B, etc. at the plug. (won't be done till spring though) If anybody knows for sure, could they please post here and could this maybe become a sticky or something? There are SO many posts about this topic and the question keeps coming up because they contradict each other.
Very Thankful,
Mike
Old Dec 21, 2004 | 05:36 PM
Reds ttype's Avatar
Car: Turbo Buick
Engine: whistling V6
Transmission: lots of broken ones
same ecm I have ..I just posted my findings
https://www.thirdgen.org/techbb2/sho...hreadid=271444
I cut my iac plug off a 97 s10 with 4 cylinder
the colors match my colors on my truck with the way I poted it to be wired
Gm dont change their colors so all iacs with that plug should be same order
Old Dec 21, 2004 | 05:51 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
http://www.turbocity.com/product_inf...products_id=50
http://www.turbocity.com/product_inf...products_id=44
Old Dec 29, 2004 | 06:28 AM
SB406's Avatar
Car: 71
Engine: 406
I forgot to put this before, in case anybody was wondering.....The flat 4-prong connectors for the 454 TB are also available on some dodges. I got one off a 3.0L Dodge Spirit I was scrapping. The wires are not the same colors, but it plugs in. A 95 Dodge Van I have has some on it too.
Old Dec 29, 2004 | 02:49 PM
Ronny's Avatar
NOW THIS IS THE 1984 VETTE CROSSFIRE "STOCK " HARNESS WITH A 7747 ECU.
TPS....
CF wire harness - 454 sensor position
blue driver front
black driver rear
grey pass front
IAC
blue/black top most
blue/white "
green white "
green/black bottom most
454 harness(s) tps/iac were GM 1995.
seemed to work well. the GM TBI truck service manual was in error/incomplete.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Dquickshift
Aug 12, 2015 06:21 PM
