Would this even be something to look into?
Old Dec 27, 2004 | 04:59 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Perfectionists can stop here...
For the rest of us, my "Problem" is that eventually I'm going to have to look into a new fuel injector (one leaks slightly) for my lo5 vehicle, and I was curious if it would be worth while looking into a set of good condition used 65pph injectors from the 9C1, or just pass and the stockers?
I'm only bringing this up because I'm not into the prom tuning yet - give me time - but I have heard nothing but comments about the stock TBI setups not being able to provide enough fuel - sometimes in even stock conditions? I figured that since I eventually will get into prom burning - would this be something to look into until I can tune the fuel curves effectively myself?
Would there be any gain in power to be seen, or am I just wasting my time?
The vehicle has no mods as of yet...
Old Dec 27, 2004 | 05:14 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you see a set for not too much, grab 'em .
I wouldnt use them yet untill there is reason to, like being short on fuel after mods. Your car will be rich if you just drop them in.
Old Dec 27, 2004 | 05:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree. Hang on to the them and set them aside until you are ready to go. See if you can nab one out of a yard if your leaky one is causing headahces at this time.
