Injector ?
Old Dec 30, 2004 | 08:53 PM
BlazerGuy 90's Avatar
Injector ?
I have an injector that I need to know the PPH rating on, the number on the injector is GM5233565*DED, can anybody help me with this ?.
Old Dec 31, 2004 | 09:35 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Well, whatever it is, I don't have it on my list of TBI Injectors...
Old Jan 2, 2005 | 10:45 PM
Injector ?.
GOY
The injectors I have came out of a 1980, 6.0L caddy, if that helps, is there a site I can go to that lists injectors by flow rate ar something like that ?.
Old Jan 2, 2005 | 11:29 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
There is. Ill see if I can dig up a link.
Old Jan 4, 2005 | 05:15 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
If they came out of a 80s 6.0 liter Caddy, then that engine was rated at something like 150 fwhp..... which probably means the injectors are on-par with those used in the 170 fwhp LO3. i.e. not very large output (51 lb/hr IIRC).
The pn you have seems odd. See this thread for info:
http://www.crossfire.homeip.net/cfte...ID=18&CAT_ID=1
There are many GM pns for TBI injectors, but I haven't seem them collected under one thread in a while. HTH.
Old Jan 4, 2005 | 11:06 PM
Link doesn`t work,
I wish GM had a listing for there injectors, it sure would make it a lot easier to figure out what you have, and to find what your looking for.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
