Head 083, and cam qustion
Old Jan 3, 2005 | 09:38 PM
NEEDforSPEED's Avatar
well here we go!
are the 083 any good these are the 350 tpi heads?
could i use them on my 305? i dunno what comp i would get...
could i mill them to get 9 to 5 or 10 to 1 comp....
other wize i might grab a set of the 081's
heres my next qustion....
LT1 or ZZ4 cam.... With that in mind....
would i need screw in studs? or whatever
what would be a good cam to run with those heads
They will be ported.... What's a good combo?
Im going to top this all off with a Victor Jr. intake....
any thot or suggestions
Old Jan 4, 2005 | 03:31 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Go with 081's, same flow characteristics as 083's but smaller chambers to keep compression up.
Intake is overkill, I think, not a good match for the setup.
Get the valve guides clearanced for the lift of a bigger cam (LT1 lift might be ok though)
Cam: LT1 if you're a beginner prom tuner, ZZ4 if you have a good handle on tuning proms, no cam change if you can't tune.
Probably safe with pinning the studs with either of those cams.
Jake_92RS
Jan 28, 2020 10:37 PM
Chuck84TA
Jul 15, 2016 09:05 PM
michealleger
Aug 26, 2015 03:29 PM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
