et times?
Old Jan 3, 2005 | 08:57 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
et times?
Hey guys i just wanted to know if some of you guys could post some et times.I am building 350 tbi w\edelbrock heads and crane cam,670tbi etc. and i wanted to see if anyone was running a set up close to this.to be honest most of the times i see in here are no to great with tbi so i was thinking of a change to tpi? the best my cars has been is a 14.52@95. mph w\stock 350 from pace performance' edelbrock tbi intake'headers'3 inch ex.a eaton posi 373.gears and slicks and a tci 700r4 trans w\2800 stall and custom chip. thanks
Old Jan 3, 2005 | 09:31 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I'm really surprised your not running better than that. Those are times that I expect out of my 305 when I get the tuning dialed in a bit better. You say you have a custom chip. Did you tune it yourself?
Old Jan 3, 2005 | 09:53 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
My best time was 13.65, 2.1 sec 60' with a best 102.1mph. Xfire Corvette running 3.07 gears and stock tires.
Old Jan 3, 2005 | 10:09 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
no the chip is by fast chips,this a stock 350 truck motor w\the swirl port heads the cam is only193 dur 385 lift@.50 so the cam 'heads' and stock t\body are killing me. i am looking for easy 13s high 12s on motor after the change.
Old Jan 3, 2005 | 10:24 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
the 670cfm tbi prolly isnt killing you as much as you might think. Like you said before, heads and cam. Definitly ditch the heads and cam before you spend the $ on a tpi system. swirl port heads are horrible, unless all you want is low end torque.
Old Jan 3, 2005 | 11:38 PM
azvolfan's Avatar
Sounds like you need some of the 083 heads. They are the 350 TPI's. Should be alot better than the 350 swirlports.
Old Jan 4, 2005 | 05:08 AM
ben73's Avatar
My 383 TBI (Crossfire) ran a best of 12.81 @ 107mph last year. 60' was 1.76sec on normal street tires.
Usig AFR195s and a mild hyd roller 216/220, ~500lift.
Will be racing tomorrow night if the weather is good, fingers crossed for a new best!
Ben.
Old Jan 4, 2005 | 05:12 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Swap h/c, but do the ultimate mods with your stock throttle body.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
