warm up time
Old Jan 8, 2005 | 07:58 PM
icarus402001's Avatar
warm up time
My 92 RS seems to take a real long time to warm up. After 10 minutes, the idle is still at 900-1000. I would think it should have slowed down by then. The coolant temp usually reads 110 or so. I know these guages aren't dead on but how much variance can there be when the fan on temp is within 10 or 15 degrees of the fan starting?
Old Jan 9, 2005 | 05:18 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: warm up time
well it definitely is cold outside, and colder air translates into denser air, which means a higher idle. The IAT isn't all that great at telling the computer it needs more fuel in our sub-freezing weather. But yeah, my car usually takes about 5-8 minutes of physical driving before it gets warm, or about ten minutes of idling.
If there's anything I learned, it's not to even bother trusting the stock guages sometimes. But only 110 after ten minutes? That seems like something's off. I don't know any "safe" way to check if the car is hotter, but try putting your hand on the radiator cap and feeling for it. My guess is that your guage is off, that's all.
Old Jan 9, 2005 | 05:50 AM
Thanks for both replies, BTW. I replaced the water pump in October. Of course I paid closer attention to how long warm up took while checking for flow and leaks, etc. The hoses felt like they were in the ballpark with the guage( I'm a boiler tech by trade, sensing temp by touch is a constant diagnostic tool).
Old Jan 9, 2005 | 12:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is that after 10 minutes of driving, or 10 minutes of idling?
Old Jan 10, 2005 | 04:58 AM
I pulled and cleaned my IAC yesterday. That seemed to do the trick.Warms up quicker, idle comes down sooner and is much smoother. It's almost like when you're not sure if it's stalled or not. Now my idle seems low. Low, like it's gonna stall, low. It stays around 500-550,though. Doesn't waver much. I'm gonna let it go. Probably just something new I have to get used to.
Old Jan 10, 2005 | 05:03 AM
BTW. Thanks to Shifty, Dimented and all of you other long time, experienced, Willing- To- Help- Out- Another- Thirdgen- Owner kinda folks. I've gotten lots of info good from all of these boards which has been indispensible.
stalkier
Aug 13, 2015 12:59 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 8, 2015 12:07 PM
