Need help on intake.... to get a good combo
Old Jan 9, 2005 | 10:51 PM
NEEDforSPEED's Avatar
What is a good intake to go with a 305 TBI
with 081 heads and LT1 cam,
i was thinking air gap or victor...?
Old Jan 10, 2005 | 08:38 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
What kind of hood do you have? and how much tuning do you want to do. When you put a big intake on you really need to spend some time with your AE tables or better known as pump shot. Air velocity slows way down at idle and then pics up fast when you get in the throttle so you need a ton more pump shot to avoid a bog or pop. RPM intake is a good if not one of the best street intakes, but alot of guys on here have had good luck with the low profile single planes like the accelerator or torker II, plus they'll fit under a stock hook where a rpm is gonna be close....like too close.
Old Jan 10, 2005 | 02:16 PM
i have a 4" cowl hood
Old Jan 10, 2005 | 03:56 PM
BMmonteSS's Avatar
Car: 84' Monte
Every test that I've seen with a carb shows that RPM kicking asp below 4000 rpm, even through 6000 and 2-3 hp behind obove that when pitted againsta a victor. If your wanting to go MPI some time in the future a victor would be a good canidate for a DIY efi intake. Also the RPM flows more air than a stealth ram and has runners within a half inch of the stealth ram, only thing it has over the rpm is plenum volume and bling. Check out www.stealthram.com (i think thats it) they have some very interesting flow test. Kinda made me wanna slap some injector bungs in a rpm.
Old Jan 10, 2005 | 07:13 PM
sunset92's Avatar
Car: sunset orange 92
Engine: 5.0
Transmission: t-5
i have the performer rpm and it is great!!! i had to gring the center 4 bolts holes to fit correctly but it worked great!
Old Jan 10, 2005 | 08:00 PM
did you pick out more low end or mid rage etc... what diffrents can you feel?
Old Jan 10, 2005 | 08:36 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
right now with a mildly modified chip i have more low end... it kinda sputters up top. but between 1500-3000 it pulls like crazy! especialy when i went back with the tbi from the carb. the carb was pretty good but when i got the 670 i think it helped alot.
customblackbird
Aug 15, 2021 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
