looking at some heads, need opinions
Old Jan 8, 2005 | 09:02 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
There is a guy here in town that is selling a set of 350 heads. In the description it says that they came off of a built 350.
Says .190 intake valves .202 (then nothing but i guess exhaust?)
Anyhow, i dont know much about heads, he only wants 50 bucks for them. Does this sound like a deal?
Old Jan 8, 2005 | 10:27 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Call him up and see what kind of shape they are in. Do not buy them no matter what he tells you. Instead, write down the casting number on the heads, go home, and post the numbers. Depending on what the casting numbers are, it may or not be worth buying. Sounds like the add was screwed up. Its supposed to read 2.02 intake 1.90 exhaust.
The casting number is the number in the center of the head underneath the valve cover.
Old Jan 9, 2005 | 08:12 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
naa, actually it is either 1.94 1.5 or 2.02 1.6 Biggest exhaust valve you can get in a stock small block head is the 1.6
Mortec.com is a good place to check out casting numbers. You need to take into acount machine work when ever you check out heads. If they need valve guides and the seats recut your going to be pushing the price of some of the cheaper performance heads out there that will give you 30-75 hp more than any stock head.
Old Jan 9, 2005 | 09:56 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Your right. I shouldn't be allowed to post when I'm that sleepy.
Old Jan 9, 2005 | 09:34 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Im gonna call him tommorrow and ill post again
509 camaro fan
Sep 6, 2015 10:43 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Aug 25, 2015 01:46 AM
