Ok so i picked up a 350 TBI
Old Jan 13, 2005 | 07:17 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Now from what I understand i need the 350 knock sensor.I am going to bolt everything from the intake up onto the 350 to the 305.Now by doing thsi from what I understand the 305 computer will run it? or are both the assemblys the same the motor is from a 1994 gmc.
Old Jan 13, 2005 | 08:01 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Spend a few minutes of your time searching for "305 TBi to 350 TBI" or alone those lines. The posts that come up will tell you everything you need for this swap. Because I am so confident that you will find your answer I will shut this one down to save some bandwidth. You can use the stock computer but you cannot use the stock chip.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
