Causes for Low Fuel Pressure?
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey guys,
I am currently diagnosing a problem with my 305TBI Camaro. I am starting to think the car is being starved of fuel. I am putting a new fuel filter in it tomorrow(If it doesnt snow.) But I would like to know what other causes are there for low fuel pressure.
Thanks,
Mark B
Thanks,
Mark B
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Your fuel pump could be dying. They tend to die in these TBI cars pretty easily and aren't very strong to begin with. Might want to get a FP gauge so you can see what your pressure is at.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 97 Z, 92 C1500
Engine: 5.7L, 5.7L
Transmission: 6-spd, 4-spd auto
Have also seen the hose that attaches the pump to sending unit in tank go bad (they get soft) and cause low pressure. Might as well replace the pump while you are in there.
Engine: 305 TBI
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Engine: 96 LT1
The 190 pump doesnt say its for high pressure use? Will it work with my new TPI motor? Or should I go with the 255 High Pressure one? Id rather pay the extra $30 now then have to do this fix again!
Car: 91 Camaro Vert
by high pressure, they mean REALLY high pressure.. like 100psi plus for boosted apps....
the 190 is a EFI pump that will work great for you. i have a 225 (not high pressure) but i wouldnt reccomend it for the TBI cars... simply because the regulator is right on the edge of not being able to return fuel back quick enough.
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
if you need a fuel pump i have a brand new walbro 190lph unit sitting in my room... i live in edison/new brunswick PM me if your interested
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
