EGR Delete question
Old Jan 18, 2005 | 04:36 PM
iPodJunky's Avatar
EGR Delete question
I just installed a 5.7 TBI in my 92 RS and am currently NOT running an EGR valve or EGR solenoid on it. Has anyone else deleted their EGR system, and if so, did you encounter any adverse effects?
Old Jan 18, 2005 | 05:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need to remove it from the chip to do it correctly. EGR is actually a good thing. You can certanly run without it but chances are you will get a constant SES light. You will need to do chip work to get that 350 to run so you can just fix it then.
By the way, welcome aboard
Old Jan 18, 2005 | 10:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The computer will remove fuel via the bpw constant and add a few more degrees when the non-existant egr is active. This can lead to possible detonation since the exaust from the egr not only cools the mixture, but is also fuel for combustion. Without it, you can be lean with extra timing, which is a good recipie for having detonation.
To tune it out, you disable the egr so no extra timing is added/fuel removed and then you tweak the fuel/spark tables to suit your taste.
Old Jan 19, 2005 | 09:34 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Great way to get detonation at part throttle. If you pull back the timing a few degrees to get rid of it the engine runs poorly @ anything but cruise and gets terrible gas mileage. All I was missing was the EGR valve. As long as I was driving it hard, no check engine light. If I just cruised along at 60-70 the light would come on after about 5 minutes.
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
