tbi gurus need assistance
Engine: 350 tbi
Transmission: th350
I can't get my tbi 350 to pass emissions. i put my scanner on it and it reads like this.Sensor Idle 2500 2500 gauge reads 210 degrees
Tps .64v .95v .95
Cool Temp 185 186 188
O2 .23-.85 .14-.87 .07-.85
Vss 000 000 000 it was in park
Rpm 675 2500 2500
Blm 108 108 108
Mat 080 185 dropping 24-311 kept jumping around
Map hg 09 07 07
Map v 1.19 .78 .78
Int 128 119 121
Iac 000 037 059
Idle after 2500 for 10 mins
Tps .66v
Cool 183 gauge reads 200
O2 .18-.88
Vss 000 park
Rpm 850-900
Blm 108
Mat 177
Map hg 09-10
Map v 1.19-1.25
Int 102
Iac 022
These are the specs that i got with engine off key on the Tps
reads idle .62
quater 1.95
half i get a side ways triangle and it reads .00 up to .99 then goes to 3.00
I don't know thanks for checking it out for me
The emission i fail on is hc the spec is 200 and last time i took it i blew a 400 before that it was almost 800 need help thanks.
Tps .64v .95v .95
Rpm 675 2500 2500
Blm 108 108 108
Map hg 09 07 07
Map v 1.19 .78 .78
Int 128 119 121
Iac 000 037 059
Tps .66v
O2 .18-.88
Vss 000 park
Rpm 850-900
Blm 108
Mat 177
Map hg 09-10
Map v 1.19-1.25
Int 102
Iac 022
reads idle .62
quater 1.95
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well your BLM of 108 means you're running pretty rich. Sounds like your tune is off. Is this a stock motor, or a 350 swapped in a thirdgen?
Engine: 305 TBI
Ok but is it in a thirdgen right now? What's your car. What was the original motor that came with the car, 305 TBI? If that's the case you are goign to need to make changes to the PROM chip to correct your fueling.
Engine: 350 tbi
Transmission: th350
so ifound that the # 8 cylinder wasn't fireing cause teh plug was covered in fuel and when i pulled it a cloud of smoke kind of like fuel evap came from the tbi. I just gave the thing all new parts hope it helps any other ideas please help
rs_z28_vert
Sep 30, 2015 09:47 PM
