350 TBI from fullsize chevy?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Would the motor from a 88-93 fullsize chevy work to replace my 305 tbi? They look almost identical and some of those trucks came with 220hp 350s
thanks
thanks
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
It should work. The only thing that you might have to change is the accesory brackets. the only difference in them should be the oil pan. but all you would have to do is pull the one off your 305 and put it on. Interelly the oil pump pickup might be different. I am not for sure about that. other than that every thing else should be the same. When you have them both out you might check the sensors also to make sure that they are the same.
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
It willl work fine, I did the exact same thing, i put a 95 350 pickup engine in my 89 RS, just take the accessory brackets and accessories of your 305 and they will bolt right up to the 350, (its the same block with same bolt holes) the oil pan from the truck will work too, its the same, I didnt have to do anything with the oil pickup or anything like that, and then I used the 305 intake, and distributor , its all the same, so good luck, and if the engine is a L05 (check the code sheet on the donor truck) then it will be a 220 HP engine, so have fun and the difference will be greatly noticed between the engines, the only real work you will have to do is tweaking the idle adjustment on the front of the TBI, the adjustment screw is behind a metal cap on the drivers side of the TBI unit, just pop off the metal cap and a small torx driver will allow you to adjust it, Have Fun
Car: 1989 Camaro RS
One other thing, make sure you get a 350 knock sensor (a must) or your car will not run right at all, and this would be a good time to replace the sensor that controls when the electric radiator fan comes on and off, since they seem to crap out alot,
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Look here.
Bone stock (approx 200 fwhp), mid to high 15s. With modified exhaust, intake, cold air induction, timing and ECM, mid 14s should be easy. 4100+ lb similarly modified Bcars with LO5 run mid 15s, so you should be well into the 14s with the same type of mods.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Gnarley_Boarder
can you keep the LO5 intake and TBI? is it the same? what baout ecm?
Car: '90 RS
Engine: 377 LSX
Originally posted by Formula4Speed
What about the fuel pump? I would think you'd need to upgrade that but I could be wrong.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
so lets get this straight.The motor i got is a L05 from the oil pan to TBI
I can keep it all intact and drop it in with the following mods
knock sensor
new chip
knock sensor
new chip
Car: '90 RS
Engine: 377 LSX
knock sensor
new chip
knock sensor
new chip
Add an ESC module, and 350 injectors if they don't already come with your new LO5. The chip will be the key. Keep an eye on that fuel pressure. It may be a good idea to spend another 100 and get a pump that will maintain the pressure that motor will need at 4k rpm.
Car: 1983 G20 Chevy
Transmission: 4L60
A stock TBI truck engine only makes 200 or 210 hp depending on the year. That is with a much less restrictive exhaust and air cleaner than a 3rd gen. The 350 does make about 30 ft/lbs more torque though.
Car: 1991 Pontiac Formula Firebird
Engine: 350 TBI
Like XJCAMARO, I also have a 350 from a 95 truck under my hood. As stated in the previous replys you'll need to make sure you have the correct knock sensor for a 350 and a new chip. Of course if don't need to drop the L05 in immediately it would be the perfect time to swap in a better cam. Just like it's little brother the L05 has a very small cam.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: Th-700r4
I have a lo5 with the Eldebrock power package in it. I'm swapping my 305 for it. I have the chip that came with the package will rhat work?
Engine: 350 TBI
I almost forgot
I had to change the flexplate out to the smaller one that was on the L03 in order for my starter to work. The 350 truck motor had a larger flexplate and I almost missed this observation before the swap. In the end I couldn't get the old one off the 305 and just bought a new one fom JEGS fairly cheap.
I had to change the flexplate out to the smaller one that was on the L03 in order for my starter to work. The 350 truck motor had a larger flexplate and I almost missed this observation before the swap. In the end I couldn't get the old one off the 305 and just bought a new one fom JEGS fairly cheap. Member
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
when it comes time for you to do chip tuning, let me know what you do to get a good tune out of it. My current chip in my LO5 sucks at higher rpm (mostly around 50+mph) it literally chugs around and hesitates pretty badly. My LO5 is from an 88 truck and after i did the knock, 350 injectors, and esc it came out lean. Anyways goodluck on the swap, mine was straight forward so nothin to worry about.
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
