Air Fuel Ratio Gauge and wiring it into the harness????
Old Feb 24, 2005 | 04:58 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I'm guessing that the O2 sesnor wire comes into the computer through the wire bundle in the passenger side kickpanel. Is this right? I'm trying not to drill a hole through the fire wall.
Old Feb 24, 2005 | 05:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You shouldn't have to drill a hole. When I installed mine I just found a rubber grommet where other wires were and just slipped it through there. I didn't splice it until the wire was close to the 02.
Old Mar 4, 2005 | 02:57 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I have read several posts where people have had problems with odd gauge behavior when they splice into the O2 wire close to the oxygen sensor. Autometer AFR gauges also mention in the instructions to tap into the harness close to the ecm, and not close to the O2.
On my 92, I just tapped into it near the ecm since it was easier to do anyway. I think it was a purple wire, but check a wiring diagram before doing anything.
RazorN8
Jan 7, 2022 11:44 AM
Reddeath210
Oct 6, 2015 08:20 AM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
