!Throttle cable & 1" spacer boggle!
Car: 91 RS
Engine: 305 (lo3) T.B.I
Transmission: TH700R4/B&M shift kit
Hi all! I recently installed a one inch TBI spacer and found out that the throttle cable would no longer reach the TBI. I then noticed that the cruise control cable mount hole was almost the same as the mount for the throttle cable and that I could ditch the cuise control cable and put the throttle cable in its place. The new location raised the throttle cable high enough to fit again and pulls the blades to WOT and pedal motion is smooth. I would just like to see if anyone knows of a common solution to the cable length problem or has any comments about my quick fix method.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If the geometry and tension on the tv cable for the trans are not the same as stock you'll burn out the transmission.
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
what about those with a manual trans? some people say there is a benefit of the spacer, others say its worthless, is there any dyno proof to support either? i would like to know b/c i am considering this mod as an option
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Some one needs to shed some more light on the TV cable thing cause I have a 1in spacer and all my cables are fine.I've hear of trannies burning out because teh cable isn't adjusted property but what is adjusted properly. I have mine adjusted to how I want the tranny to shift. Is there a preset?
TheTraut88
Sep 7, 2015 05:22 PM
