305 TPI heads
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
305 TPI heads
how much of a differents will stock 305 tpi heads make? and then how much after port and polished? also, someone told me this would affect my emissions is that true, because i have to take the test ever other year.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When ported the TPI heads can make a nice difference. You would want to put in a cam that matches them though. It would be pointless to do all that work and leave the stock cam in there. Provided you do the necessary tuning, leave your cat in place, you shouldn't have to worry about emissions.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
a nice cheap cam that makes a differance with 305 tpi heads wold be an l98 cam but you will definitly need to get into chip tuning when you get into cam and head swaps.....
Car: '90 RS
Engine: 377 LSX
Originally posted by IROC_UPINYA
What cc are the 305 tpi head. Are they the same as the 305 H.O. head 53cc?
Car: currently thirdgenless!!!
I did the L98 cam and wish I had done the LT1 cam. Just make sure your springs can handle the lift of the LT1 cam. If you keep your rockers stock I think you'll be ok (check me on that Shifty).
If you want to do an L98 cam make sure you get one from 89-90. They look like they have the best specs. The 91-92 looks good also. The cam specs can be found on the Thirdgen tech data page. Stay away from the 87 L98 cam. It is only marginally bigger than the 305 cam.
Here is the data from the tech data page
1987 cam specs
(LB9/ L98) 14093643* .404 .415 202 207 114.5 (115/-114)
1988-1989
(L98) 10066049* .415 .430 207 213 117.0 (116/-118)
1990-1992
(L98) 10111773* .413 .428 202 207 114.5 (116/-116)
I stand corrected on one thing. It's 88-89 that was the biggest cam, not 89-90.
1987 cam specs
1988-1989
1990-1992
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
Originally posted by Ronny
i have a crane computer hydralic flat tappet cam 4 sale 210/216 @ .05 114 lsa. used 2 seasons. $45 plus ship cost.
Sanjay
Aug 12, 2015 03:41 PM
