Idle Up and Down
Old Mar 19, 2005 | 08:02 PM
Raul_Chile's Avatar
Idle Up and Down
Hi
I have a 350TBI 1990 all stock, today I probed my engine with new ring (Still out my Car) and the idle up and down, beetwen 500 y 800RPM aprox. I adjust advance at 0 degree without Spout, I cleaned IAC and passager but the same problem.
I hadīt today my laptop with WinALDL connected so I canīt to see other parameters as O2, MAP,etc.
Regards from Chile
Old Mar 22, 2005 | 02:53 PM
Ronny's Avatar
did you run car for a while at highway speeds? over 40 mph? that may fix the problem. OR a vacuum leak?
Old Mar 22, 2005 | 10:53 PM
Raul_Chile's Avatar
Re: Idle Up and Down
Originally posted by Raul_Chile
Hi
Regards from Chile
Sorry, my engine is out the car. Two month more i will put it.
Since, my problem is in Idle. Is posible that be vaccum leak, but my doubt is FOR WHAT Up and Down rev.
Old Mar 23, 2005 | 08:30 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check all of the vacuum lines that plug into the TBI unit. Trace them with your fingers and look for cracks and or any splits in the material. Also, look at the base of the TBI unit for a leak. That is a common area for these cars to develop a vacuum leak.
Old Mar 23, 2005 | 07:00 PM
Raul_Chile's Avatar
Re: Re: Idle Up and Down
Ok, I will check all that.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
