Strange idle increase after drive
Old Mar 22, 2005 | 09:45 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
I had to screw the throttle stop screw to turn up the idle after my car would stall after decelleration or idling in drive or changing gears from park/reverse to drive and back. So now when I start the car, it idles at about 700-800rpms (i know the car should be able to handle 500rpm idles but for some reason mine would stall) When I shift into drive, it idles at about 600-700 rpm which is better.
The problem is when i shift back to park after driving, it idles at about 1200-1300rpms and never goes back down.
Old Mar 23, 2005 | 04:13 PM
Ronny's Avatar
inspect IAC and possibly clean passages in TB as well as IAC?.
Old Mar 23, 2005 | 08:31 PM
safemode's Avatar
Car: camaro rs
in my attempts to fix the stalling problem that was occurring before I changed the throttle screw, I removed the IAC pintle and cleaned it (as thoroughly as i thought possible) and put a little synthetic lubrication (for bearings and such) on the pintle's shaft.
Though i suspect it's a problem with either the pintle or the motor in the IAC that is causing my problems. It doesn't seem to be able to catch up when i'm braking as the engine will sound like it's surging and the rpms will jump up as i'm decreasing a couple times before settling at idle.
Old Mar 23, 2005 | 09:26 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Could also be problems in the vacuum lines. Check all the hoses for integrity.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
red90IROCls1
Aug 25, 2015 06:56 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
