i got a 91 tbi rs
Old Apr 2, 2005 | 12:43 PM
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
i got a 91 tbi rs
last night i was working on my car at my Friends shop. his dad is all hotrod expect and stuff. so anyways he was talking bout flipping my carb cap upside down and we did it. is that good or bad. it preforms way better then it did. someone help me out please
Old Apr 4, 2005 | 11:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I used to do that with my dad's '69 Impala.
If the air cleaner has a small snorkel that restricts flow, then it will "help" the car run better. The only "bad" thing it does is bypass the thermovac system, which may cause some cold driveability issues.
A lot of guys run open element air cleaners with TBI. A better choice is to remove the snorkel restriction by adding another snorkel with an air hose run to a cool air source.
(And, since this isn't a carb situation, moving to the TBI forum...)
Old Apr 4, 2005 | 01:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Five basically nailed it on the head. It is an old hot rod trick to flip the lid. You are not hurting anything by doing it but you may want to look into a custom intake and or a cheap open element.
Old Apr 4, 2005 | 11:43 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
yep, make the engine a little bit louder (at least on my friends Delta88)
Old Apr 5, 2005 | 12:01 AM
transram88's Avatar
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
if you have a four barrel.....when you hammer it, you can hear them all open up...some kind of super vacuum noise! (just like my X ride...the delta 88)
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
