Open Element
Old Apr 18, 2005 | 07:49 AM
lxcamaroxl's Avatar
Car: 92 Camaro (R)eally(S)tock
Engine: 305 TBI
Transmission: Auto 700r4
Open Element
I am going to perform this mod on my car i just want to clear some things up
1. On page one, step3 in http://snflupigus.tripod.com/tech/op...tep1/step1.htm
It states that you have to take the breather filter off from the bottom of the air cleaner. Does anyone have pictures of this.
Also where do i put the termac?
What do i do after i unplug the IAT sensor?
What does the spacer ring look like?
Theres pictures and explaination of some things. I just need more explanation.
Old Apr 18, 2005 | 11:55 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Theres an open element FAQ at the top of the board. See that first.
As far as the breather goes, you can get a push-in filter from most autoparts stores. They should even throw in a grommet but make sure to take the breather tube (black thing haning out the pass. side of the stock air cleaner) with you as a reference for the size. IIRC, some of thethe older style aftermarket valve covers have different diameter openings for the breathers.
The thermac is gone. Just pull the stove pipe off, plug the vacuum port thatll be left open when you remove the aircleaner, and thats it.
The spacer ring sits under the stock aircleaner and allows it to clear the linkages and such. You probably wont need this with your new filter if its a non-drop base.
As far as teh IAT goes, remove it, and zip-tie the sensor to the firewall somewhere (make sure its plugged in, of course).
Old Apr 18, 2005 | 11:57 AM
lxcamaroxl's Avatar
Engine: 305 TBI
O Ok thats pretty cool. I did look at the other threads but i needed something more talored to my questions.
Old Apr 18, 2005 | 12:29 PM
lxcamaroxl's Avatar
Engine: 305 TBI
would this be a really good one. http://www.proformparts.com/v2/catal...690series.html
Old Apr 18, 2005 | 06:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That one would be fine. You can really use any size you want provided you don't exceed hood clearance with a super tall element.
Old Apr 19, 2005 | 07:12 AM
lxcamaroxl's Avatar
Engine: 305 TBI
yea i know what you mean.
Old Apr 20, 2005 | 02:05 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I did not like the idea of zip ties, so I drilled a hole in the replacement air cleaner base for the sensor to pop into place, I also just used a push in type of breather.
this pic shows the original tube for breather, which do not use any longer
Old Apr 20, 2005 | 02:12 PM
lxcamaroxl's Avatar
Engine: 305 TBI
o i see what you mean. I can drill a hole. Thats good, no zip ties.
You even painted parts with that tasty looking orange
Old Apr 20, 2005 | 02:33 PM
gscz28's Avatar
Car: 89 iroc
the base of the air cleaner I believe has an area marked for the IAT.....
I just got I my car back from paint check it out
Old May 9, 2005 | 09:02 AM
lxcamaroxl's Avatar
Engine: 305 TBI
Wow, Beutiful
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
