cross-fire hood
Car: 83 camaro z28 cross_fire
cross-fire hood
hey i have a cross fire hood with the flapper for the "Ram Air" when you smash the accelerator the flap opens allowing air to flow directly into the intake. do any of you know where i can get another little flapper motor???
I'm assuming you have a cross-fire camaro then (i have one too
) and the best place to get a motor for the "X-Ram" as it's called, would be a junk yard. But it's rare finding one in a junkyard so i'd say look around for specialty shops or a shop that can order it for you.
) and the best place to get a motor for the "X-Ram" as it's called, would be a junk yard. But it's rare finding one in a junkyard so i'd say look around for specialty shops or a shop that can order it for you. Supreme Member
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
) and the best place to get a motor for the "X-Ram" as it's called, would be a junk yard. But it's rare finding one in a junkyard so i'd say look around for specialty shops or a shop that can order it for you. most people will say worse, but i say they are WRONG! it was the strongest thirdgen until the IROC came about, and had just as much torque. Started right up for me everytime, even after storing it for winter, and had no problems. Plus they had one of the best excellerations except for the L98 350 TPI
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
haha, wow, sorry my dislexia took a turn there...
also, i noticed the question said "are CFI's better then TBI's?" in my opinion i say yes, but it's argueable.
Car: 1982,Z/28
Engine: 355
Transmission: t350
flapper hood motor/crossfire
as far as a motor for the crossfire hood flapper, you could try a motor for a second gen camaro with cowl induct, might be very simillar-maybe from a 1979,???
Car: 1982,Z/28
Engine: 355
Transmission: t350
hood flapper motor
try second gen camaro,maybe a 1979 with cowl induc.--------try either , paddock, or year one,--one of them offered it.--or if yours is just lazy,[slow],or not opening fully try cleaning with electrical cleaner, ----i did this and also took motor apart and shortened the spring inside for less resistance.----------carls1982z
Car: 1982,Z/28
Engine: 355
Transmission: t350
crossfire bad rap
which is better single TBI or crossfire, thats a easy question ---TBI , but only because, of the time [82] that crossfire came out, and no one knew how too work on them, and all the mods you see now are for single TBI.---------CROSSFIRE GETS BAD REP
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
