intake
Old Apr 24, 2005 | 11:58 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
intake
whats a good intake manifold for a 305 tbi? i all ready have a adaptor plate so i have alot of options
Old Apr 25, 2005 | 05:58 PM
Car: 1988 formula
so no one buys aftermarket intakes huh?
Old Apr 25, 2005 | 10:33 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
A lot of people on here, like me, have found the Edelbrock Performer TBI intake to be an excellent direct bolt on that has all the stock fittings for EGR and everything. This intake has larger runners and is a little bit taller than stock. It gives it a lot more air in the mid to upper RPM range. Since you have an adapter, you can look at other Edelbrock intakes as well as Holley intakes. Just keep in mind most of those intakes will require some modification if you want to keep the car EGR and emissions legal.
Old Apr 26, 2005 | 10:22 AM
Ronny's Avatar
i choose the holley projection TBI. no adapter plate. high rise dual plane. pleased with it.
Old Apr 26, 2005 | 10:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'm a fan of using a single plane, but you you will need to do some computer work, to get it to run right and up to its pontial.
Old Apr 26, 2005 | 11:14 AM
Car: 1988 formula
so since i have a 1988 does that mean i have to get a intake that ses its for 1987 or higher?
Old Apr 26, 2005 | 11:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes and no.
and 87+ will bolt right up. but the early intakes can be modified so they fit, the only diffrence is the center 4 bolts, they sit at a diffrent angle, you can massage the bolt holes in an early intake, so that it will bolt to your heads.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
