A simple injector test???
Old May 22, 2005 | 04:05 PM
daveward's Avatar
Car: '82 Mercedes 300TD
Engine: '92 305 TBI
Transmission: 4l60E
I have just replaced the two injectors with a matched pair and new bored throttle bodies. I have also made the fuel pressure modification mentioned elsewhere in this forum. I am sure I have an electrical problem that is causing the injectors to now not get 12v or any pulse signal whatsoever.
However, it would be re-assuring to eliminate the injectors themselves as a problem Can I perform a simple test while eveything's installed on the car...apply 12 volts to the green wire or the blue wire (12v) at one of the injectors while the car is cranking and fuel presssure exists. I need so see if fuel will spray independent of the computer's command. Please tell me this is as simple as I'm making it sound.
It's a '92 Camaro 5.0 engine with TBI
Dave
Old May 22, 2005 | 06:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You can measure the resistance. IIRC, its something like 1.2 ohms for the coil. You can also momentarily apply 12 volts to the coil in the injector and see if each injector opens. One pin in each injector connector should have +12 volts with the key on. If not, then the problem is electrical, and not with the injectors or the ecm.
db057
Sep 4, 2015 07:57 AM
Justin92GTA
Aug 27, 2015 11:16 PM
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
