got the lo3 out putting in an l98
Old May 25, 2005 | 01:01 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Hey guys. I have gotten the lo3 out of my 91rs and am in the process of putting the stock l98 that i got off a buddy for a few hundred bucks. My question is will my lo3 manifold bolt up ok? I am getting a chip, larger injectors, esc and knock sensor. Any input definitely greatly appreciated.
Bill
Old May 25, 2005 | 08:15 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
The L03 stock manifold is smaller than a stock L98 manifold. Get some headers...
Old May 25, 2005 | 09:45 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
If its intake manifold, I would choose a good carb manifold plus an adaptor, but you might be talking exhaust, in which case by some headers.
Old May 25, 2005 | 06:11 PM
I already have headers and full exhaust on my car. I was just wondering if I could get by for now bolting on the intake manifold that I have do to lack of funds at the moment.
Bill
Old May 25, 2005 | 07:03 PM
steve8586iroc's Avatar
Yes, your good to go.
Steve
Old May 25, 2005 | 11:20 PM
Steve,
Thanks for the reply. That is what I will do for now.
Bill
Old May 31, 2005 | 08:57 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Sorry man, I thought you were referring to the exhaust manifold. Yeah, stock 305 and 350 intakes are direct swap.
Old May 31, 2005 | 07:43 PM
LOL!! No big thing bro. Thanks for the reply.
Bill
Old May 31, 2005 | 07:44 PM
do you guys think that this will be a good base to start from? The L98 that it is.
thanks
Old Jun 1, 2005 | 10:53 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Yes, the L98 is a better base than an L05 due to its better heads and cam. All factory TBI heads had horrible flow numbers.
Old Jun 1, 2005 | 05:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Some LO5's had the L98 cam and recent evidence has shown that LO5 (193) heads are about on par with L98 heads. Both heads (as in all GM heads) have their flaws. The LO5 head outflows the L98 head on the exhaust but the L98 flows more on the intake. You sorta have to choose the lesser of two evils. oth heads respond well to porting but you may be able to get a bit more from the L98's. Either shortblock is a great starting point.
Old Jun 1, 2005 | 09:13 PM
Shifty,
Thanks for the heads up? Oh yeah how much does it generally cost to do a head porting job?
Bill
Old Jun 1, 2005 | 09:20 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by weberflorida
Shifty,
Bill
You can do it yourself for less than $150 which includes the porting kit and die grinder. Shops will charge $500 to $2000 for a port job. For stock iron GM heads I would invest in the stuff to do it yourself. There is enough tech data here on TGO to steer you in the right direction.
Old Jun 2, 2005 | 01:34 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Shifty, what are you basing the head comparison on? Do you have flow umbers for a ported set of L05 heads? I would really like to see that.
As far as porting heads, if they are stock castings, do not pay someone to port them for you. It will costing you quite a bit. It really isn't difficult for a first timer. I have roughly 150 hours of porting time on a $9 Harbor Freight air grinder. I bought 2 new sets of Carbide bits on Ebay with 6" shanks for about $30 per set (each set brought 4). I spent a grand total of about $70 on mine, and I bought alot more bits than what was needed.
You'll find quite a few very good threads on porting from Sitting Bull, F'Bird-88, Vader, and a few other guys.
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
