broke sensor in left head need to no where to get one..
Old May 29, 2005 | 08:01 PM
25TH ANNI RS's Avatar
Car: 92 camaro rs, 01cadillac sls,
Engine: 357ci
i'm in the process of building a 355 ci and i brock the sensor in the passanger side head. does this need to be changed to a 350 and what is and a part # please...it's above the knock sensor
Old May 29, 2005 | 08:32 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
That is what they call the coolant fan switch. Did it look like this?:
Pretty much everybody breaks it at some point or another. If you were in the states you could just order an aftermarket lower temp. fan switch (Hypertech and Jet sell them) from a place like Summit Racing or Jegs. Not sure if they're available in Germany or not. Let me see if I can dig up some part numbers.
EDIT: Here's some part numbers I found for a stock replacement fan switch:
AC Delco part number: 154315
GM part number: 88961770
If you need more part numbers, just let me know.
Old May 29, 2005 | 09:27 PM
Damon's Avatar
Yeah, you need to replace it. It's the only thing that turns the (single) cooling fan on in a TBI car, unless you turn the A/C on.
While you're at it you might want to upgrade to an aftermarket one with a lower fan turn-on temperature. Stock ones don't turn on until more than 220* or so. Might want to get one that clicks on down closer to 200, or whatever will work with your thermostat temperature without running the fan constantly.
Old May 30, 2005 | 07:37 AM
Brent's Avatar
GM# 3053190 will get you a 203F fan switch.
Old May 30, 2005 | 08:49 AM
Engine: 357ci
it's the one in the other head that one is on the driver side of car this on is on the pass side. it looks like the knock sensor but on the head. i was disabled in the army and know i'm back home in alabama...
Old May 30, 2005 | 06:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The sensor that Benm posted should be in the passenger side head. It should be very close to the exhaust maniofld as pictured here,
Note that the temp sensor in tis pic is broken as well. The mushroom part of it has broken off.
Attached Thumbnails broke sensor in left head need to no where to get one..-mvc-012f.jpg
eightsixseven
Dec 16, 2024 01:50 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
