Fuel pump out tank
Old May 30, 2005 | 10:30 PM
Raul_Chile's Avatar
Fuel pump out tank
Hi
What happen if i put the fuel pump out gas oil tank?,for example in cab or outside tank. I use my 350TBI in 4x4 then constantly it pump fail and you have out tank,out pump,etc.
Regards from Chile
Old May 31, 2005 | 08:14 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There are company's that sell inline fuel pumps. It will retain the stock pickup but instead will place a pump in the feed line. Supercharger kits for LT1 and LS1 cars come with similar set-up. Aeromotive sells inline pumps I believe.
Old Jun 1, 2005 | 11:04 PM
Raul_Chile's Avatar
Re: Fuel pump out tank
Originally posted by Raul_Chile
Hi
Regards from Chile
My question is specificment for fuel pump stock in cab or outside tank.
Old Jun 2, 2005 | 06:57 PM
steve8586iroc's Avatar
How hard is it to remove the gas tank on your 4x4?
Steve
Old Jun 3, 2005 | 12:39 AM
Raul_Chile's Avatar
Re: Re: Fuel pump out tank
Is very hard.For that my question.
My friend have changed 4 fuel pump this year.,
regards
Old Jun 3, 2005 | 08:51 PM
luvmy64's Avatar
I think that even if you go with one outside the tank, you will still have to pull the tank to put a pipe in place of your existing fuel pump in order for the external pump to work. Am i right? Anyone?
Old Jun 4, 2005 | 12:45 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
That's incorrect. It might be the best way, but an inline pump can and will pull through the stock pickup.
If I were you, I'd purschase a nice inline pump and stick in close to the tank but in an easy-to-get-to area...
Old Jun 4, 2005 | 11:37 PM
Raul_Chile's Avatar
Ok, thanks.
Today I put my pump in tank again and new pressure gauge (12,8PSI )
Regards from Chile
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
