305 TBI to 350TBI
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
305 TBI to 350TBI
OK guys not to beat a dead horse or anything, Just want it to work the first time. To make this work I need a:
1. 350 Knock sensor
2. 350 EEprom
3. 350 Injectors
Nothing else matters?
1. 350 Knock sensor
2. 350 EEprom
3. 350 Injectors
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 305 TBI to 350TBI
1. 350 Knock sensor
2. 350 EEprom
3. 350 Injectors
1. 350 Knock sensor
2. 350 EEprom
3. 350 Injectors
Motor is stock for now, got it cheap so I just couldn't say no. I still need the bin and the burning software. Can i locate the bin in the DIY forum? Also the TBI I ahve has the Adj regulator on it, so I was just going to bump it up a notch till I got the 350 bin done.
Car: 1991 Chevy Camaro
Engine: 305 TBI
You should be able to find the BIN in the DIY-PROM board, no problem. Just bumping up the pressure might or might not be enough to feed that 350, it will all depend on the condition and age of the fuel pump in your car.
I think you also need a 350 ESC module too, if I remember correctly.
Engine: 305 TBI
Where is the ESC Module? In the ECU?
Found it.
Now I just picked up a 7747 ECU to go with the new L05. I wont have to mess with the chip yet because I haven't done anything to the motor yet right? Or does the exhaust count?
Engine: 305 TBI
What have you done to the exhaust? Stock, headers, cat-back?
Either way, a stock PROM will work and the car will be driveable, but it's never to early to start custom tunes.
The car came with Mac headers 1 3/4"primary to a 3"collector, 3" high flow cat, 3" cat back with Mac exhaust.
I must say that it is one of the best sounding stock 305's that I have ever heard.
I really dont want to have to do a custom tune with the stock computers if I dont have to. This winter I'm converting it to a MegaSquirt ECU.
Car: '90 RS
Engine: 377 LSX
Enh so I was an 1/8th off..... lol
Thanks for the correct.
As a second question is anyone using any of these type Wire Looms ?
I was looking at using the bracket setup but I dont have the holes in my cylinder head.
