new to performance
Old Jul 2, 2005 | 05:19 PM
Yellow RS's Avatar
Car: 91 camaro rs
Engine: 5.0 TBI
Transmission: stock
new to performance
would like to know so of the keys parts to start making my car faster
Old Jul 2, 2005 | 05:26 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Do a search but it will basically involve a full exhaust, a bigger cam, some work to the heads or different ones, gears, and alot of DIY chip work.
Old Jul 2, 2005 | 09:19 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
To put it very simply, engines are like air pumps, you basically want to get as much air in and as much air out as you possibly can.
Start by reading the stickies at the top of the page, especially the "New to TBI" thread. That will give you some good ideas on how and/or where to start. Just be patient, and don't be afraid to ask questions. We all had to start somewhere.
Old Jul 2, 2005 | 10:21 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
How much can you spend?
Old Jul 2, 2005 | 10:45 PM
Yellow RS's Avatar
Car: 91 camaro rs
Engine: 5.0 TBI
Transmission: stock
thanks-- I would like to spend roughly about a 2 thousand, also I was wondering if i should swap my 5.0 305 to a 5.7 350 do u think it would be worth it
Old Jul 2, 2005 | 11:06 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Stock for stock, NO.
Old Jul 2, 2005 | 11:39 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
First, a massive tuneup.All fluids/filters/wires/plugs/pcv valve/dist cap/rotor.Run a injector/fuel system cleaner through.Do a brake job and shock/strut job.Tires/alignment etc....What ever needs to be done
Headers/Y-Pipe
High Flow Cat
3 Inch Catback
Open Element with K&N Filter and Xtreme Flo top
3 Piece Underdrive Pulley set
Then see what ever you have left over if you dont do installations yourself.
Old Jul 3, 2005 | 12:17 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Don't waist your time on the pulleys. All the other mods recommended are key. Instead of pulleys maybe gears and a posi.
Old Jul 3, 2005 | 07:44 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You may want to consider gears as your first mod. My friend just recently swaped out his 2.73 gears for 3.73's in his mustang. I know it's not a thirdgen but we got very good before and after g-tech pro times with the swap. He dropped from a consistant 15.1 to a 14.6 with nothing more than the gears. If your car has 2.73's do the gear and posi swap first then dive into the exhaust and cam swap. You may want to stick with 3.42's instead of the 3.73's since your camaro has a deeper first gear in the tranny and your OD isn't quite as low.
Ohh, and don't underestimate the power of DIY tuning.
Old Jul 3, 2005 | 09:10 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by Yellow RS....also I was wondering if i should swap my 5.0 305 to a 5.7 350 do u think it would be worth it.
Yes, especially if you're looking for the most power you will be able to obtain in the long run.
Old Jul 3, 2005 | 05:06 PM
BM has good advice do that. It is crazy how much a gear swap will make in some instances.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
