1989 chevy blazer 4.3
Old Jul 6, 2005 | 09:55 AM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
this cars not tpi but it is tbi, and it won't get spark, new distributor, pick up coil, new ignition module, new coil, new computer, no spark but gets power to the coil? wtf any in put?? maybe esc
Old Jul 6, 2005 | 11:59 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
How dirty is the base of the dist.? The hold down clamp, base, and intake where the clamp touches have to be spotlessly clean or there wont be a good ground path for the module. For that matter, poor grounding at the block will also cause problems. Ive had both of these problems before.
Hate to say it but this is really pushing the rules of the forum.
Old Jul 6, 2005 | 09:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Take the 2 wire connector from the distributer to the coil off on both ends. Ohm the each wire while flexing the wires. I bet you find a break in the wire.
Old Jul 8, 2005 | 09:29 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Another test is to crank teh engine and see if the fuel pump/injectors come on. if so, you can immediatly rule out the pickup and probably the module.
85 Jimmy
Sep 30, 2015 07:56 AM
Night rider327
Sep 16, 2015 02:20 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
