A question
Old Jul 10, 2005 | 07:08 PM
chesterfield's Avatar
Car: Pontiac
A question
Just when you've thought you've seen it all....I found this stuff at a wrecking yard today. It was on a 79 Cadillac 6.0 although it appears that this wasn't an option until 80. It has 2" bores but the injector pod was missing. My question is, if anyone might know, is the throttle shaft from a LO3/LO5 interchangeable with a 454 TBI? The linkage lever is different so its not usable as is. Yes, I'm assuming this is the same as a 454 2" bore TBI.
Old Jul 10, 2005 | 07:10 PM
Car: Pontiac
If someone told me that Gm made an adapter for a TBI to Quadrajet I'd have said "Codswallop!"
Old Jul 10, 2005 | 07:12 PM
Car: Pontiac
Its 1 3/4" thick and has a water passage built into it.
This post for educational purposes only.
Old Jul 10, 2005 | 08:14 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
My 454 tbi came with the same adapter and provision for vacuum line to the brake booster. I couldn't use it since it would not line up with the Edelbrock’s air gap manifold. The throttle shaft from a 305 will work (I’ve done it) but you will need to cut some material off the shaft to make the 2" throttle blade to fit and the holes on the shaft barely lines up with the holes on the throttle blades.
Old Jul 10, 2005 | 10:10 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Wow, that's pretty interesting. Good find!
The IAC valve looks a little different that the usual kind you see on TBIs, I noticed. Do you have a better picture of it? Just curious.
Old Jul 12, 2005 | 09:55 PM
Car: Pontiac
thanks 86z/92rs
Benm109
I'm building a 400sbc and thought I'd tbi it. Then I started reading this forum and began to have second thoughts. (maybe over my head) so a carb is looking good but with this stuff I can go Qjet intake and work things out and go back to carb if I have to. Anyway I have an lo5 tbi and ecm but I really don't much about them. If you see anything that may be a problem from these pics feel free to point it out. thanks
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
