i found this on ebay i was woundering if anyone knows about it ?
Car: rally sport camaro
this is a RESISTOR CHIP that will be inserted between your car's IAT sensor. i was woundering if anyone has had any first hand expreiences with this so called power booster. i was just woundering. i want to know weather to consider buying this..... probly not useless someone knows it does what it says it does....... plz let me know here its is
ya i think its just a stupid thing that does'nt really do any thing
i was just woundering tho if it would actually do something like gimme some power
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It fools the ECM into thinking that the inr coming air is cooler. It therefore comepenstates with more fuel and timing. Save your money. Mods like these are a joke and can be achieved with a few penny's and a visit to Radio Shack.
Car: 97 Z, 92 C1500
Engine: 5.7L, 5.7L
Transmission: 6-spd, 4-spd auto
The short term effect of this modification will be more power - i.e. greater timing advance, richer fuel. However, the ECM will quickly figure this out and tune the motor back to stock in less than a couple of hours (through BLM, spark knock counts, etc). You can acheive the same thing by advancing your base timing a few degrees and raising fuel pressure - but again, the ECM will eventually tune this back out. The only true way to make these power modifications permanent is to burn a custom prom
Drone358
Dec 10, 2015 08:16 PM
rudolphschenker
Sep 4, 2015 02:41 AM
