Timing mark for a '91 Camaro RS
Old Jul 27, 2005 | 01:00 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
OK, I don't have a timing tab on my timing cover, and I want to wait with replacing the cover when I will replace the waterpump, change the oil.
As far as I know, the engine's all stock, so is there a way of doing it without the timing marker ?
Actually... can someone maybe tell me ... where the zero is.. in degrees.(such as 45 degrees 60 or what) .. or clock wise (1:30 .. 2 o clocl .. 3 o clock) ... measured from the center of the crank ? I would really appreciate this guys
Old Jul 27, 2005 | 04:57 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Advanced Auto, as well as others I'm sure, sell bolt on timing tabs. They should work if they are the right kind. GM used two different kinds one was mounted at 12 O'clock and the other was more like 2 O'clock. Some one else will have to chime in as to which one you'll need.
Are you absolutly sure you don't have one? Their spot welded to the timing cover, so some one would have had to mangle it pretty bad to get it off, or replaced the timing cover. If it's mounted at 12 O'clock it can be pretty hard to see. Best way is to look behind the water pump from up top, you'll need a light because it's dark behind there even in daylight. You really don't want to change the timing cover, you have to drop the oil pan to get it off, which is not fun with the engine in the car.
Old Jul 27, 2005 | 07:00 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have the same car, u need the 2 o'clock one, hope that helps
Old Jul 27, 2005 | 09:34 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Yeah
I agree ..... like I said... hadn't planned on replacing the timing cover until replacing the waterpump time would come up
I'll check it out..
Thanks guys
Old Jul 27, 2005 | 11:54 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Feeling like an idiot
OK... burried in there .. I finally did find the timing mark .. at the 12 o clock position ...
Now a question here.. .having a little bit of a problem with the rear screw for the distributor cap.. had problems removing it last time... and I don't want to strip it out completely ... is it a standard screw ... or ... what ?
I may have to get a rebuild kit for the TBI.. or... maybe new fuel line fittings and possibly look at the threads of the fuel line going into the injector housing... problems with fuel leakage there
Old Jul 27, 2005 | 11:57 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Re: Timing mark for a '91 Camaro RS
On my 91 305 TBI M5 stock motor, the timing mark is pretty much right at the top.
I am not sure if these type of motors came with a stock timing mark (on the balancer) at the "2:00" position- not likely, but possible.
Unless it is absolutely necessary to dink around with the timing, I'd leave it be until you get a timing cover with a pointer and verfiy what balancer you have.
Please consider that moving the timing mark perhaps 1/4" on the outer edge of the stock Harmonic Balancer can change your timing by up to 4*. Things can get out of hand in hurry if you
have no sure reference and you start twisting the distributor.
As BMMonte mentions, re-check for the timing tab at the 12:00 position- it should be there.
If not and you can verify you have the stock Harmonic Balancer, I would try the 12:00 position setting first.
The answer will obvious in how the engine runs. The normal max advance on these engine is about 4-6*. If you are looking at the difference between being right on and 60* off, it will be a matter of at which setting the engine will start and run.
S-D
Old Jul 28, 2005 | 12:11 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
You know what my timing mark is at 12 oclock also. I can't find a timing tab that will work. The one that I have is at 2 or so. I basically just did the best I can lining up at tdc. I was thinking of drawing a line on the balancer. Don't know does anybody know where I can get the right timing tab?
Old Jul 28, 2005 | 12:33 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well
I have to set the timing.. driving my buddy's van right now ... because I had to change my intake manifold gasket... so.. timing got messed up... idle at 1800-2000 rpm when I fired it up lol
700 rpm at idle would be correct.. ?
Old Jul 28, 2005 | 12:57 AM
Nice. That sounds like it idleing a little fast Dude 750 sounds good to me.
Old Jul 28, 2005 | 07:43 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
i havent played with timing on my car yet... I'm hoping to do it today.
My car's idle is 600 in neutral when warm, and around 500 in gear.
Now that I think about it... I'm going to advance my timing right now
Old Jul 28, 2005 | 08:25 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You don't adjust your idle speed by setting the timing. The ECM controls the idle no matter what the timing is at. A high idle is a result of advancing it too far.
Old Jul 28, 2005 | 09:19 AM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
my idle is 200-400rpms depending on if i just start it up or i just came to a stop. i love it, makes my car shake like i got something under the hood besides a cam
Old Jul 28, 2005 | 11:34 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
tell me you're joking
Old Jul 28, 2005 | 12:09 PM
jimp2001's Avatar
Engine: LO3 305 TBI
i just advanced my timing by 6* it was set at 2* retarded, now it's at 4* advance.
I feel a huge improvement. When I romp on it off the line it spins the "tire" lol
Old Jul 28, 2005 | 01:15 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Advanced
Like I said .. replaced the intake manifold gasket ... and I must have advanced the timing quite a bit when I dropped the distributor back in
Before that.. I did have that vacuum leak so idle was jumping up and down.. but more around hmmm 1000 rpm .. still a bit too high
Now it's 1800 or more rpm.. so yeah... down to 700 or 750 is where it should be
Now one question here ... overheating... can it be caused by advancing the timing way too much ??? When I started the car ... well... it heated up extremely fast ... so.. maybe my thermostat is stuck.. or I got tons of air in my system.. blocking the coolant
Old Jul 28, 2005 | 01:40 PM
jimp2001's Avatar
Engine: LO3 305 TBI
pop the cap off and see if the thermostat opens
Old Jul 29, 2005 | 12:35 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
WHAT THE HELL ???
OK, got it to TDC ... put the rotor pointing towards no.1
Engine doesn't start
And ... the TBI leaks .. .from one of the fuel line fittings... I suspect the threads may have gotten stripped .. would a rethread kit fix this ??
As far as won't start.. I doubt it's just due to lack of enough fuel... I must have either turned the distributor 180 degrees.. or... somehow connected spark plug wires in the wrong order to the cap....
Although,.. it did start before... so I'm leaning towards distributor being turned the wrong way
Old Jul 29, 2005 | 09:39 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
There isn't really such a thing as having your distributor 180° off. If you were at TDC for the #1 with the rotor pointing to the #1 plug terminal than the motor should fire.
As for the fuels lines I would check the white teflon rings that connect onto the fuel lines. Back them out and check to see if they are cracked and or missing.
Old Jul 29, 2005 | 02:08 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Well
Reason I suggested that was... I remember long time ago I did a misstake to my Spider, reconnected the sparkplug wires... knew the firing order.. but.. did it from the wrong side ... so ..
Teflon rings ... ok... now if they are indeed missing or cracked ... where can I get new ones ? ... Can one buy them separately ... do they come i nthe rebuild kit only... or... can one use .. roflmao.. teflon tape
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
