TPI Cold Air Intake for TBI
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Brightly colored graphics are one thing- measuring and folding the sheet metal to make it work is something all together different.
https://www.thirdgen.org/forums/tbi/...ght=air+intake
This thread addresses the TBI to TPI transition under the hood.
https://www.thirdgen.org/forums/tbi/...+air+alternate
I have seen everything from 4" corragated drain pipe, to PVC to dryer ducts used to draw in cold air. I could never get used to the way they looked. But, the amount of time I spent measuring and fabricating almost justifies the short cut. In the end, I do not see much noticable gain, but I'm pretty sure it can't hurt. For actual performance gains, increasing displacement combined with tuning is always sure to please.
Best-
S-D
Best-
S-D
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: TPI Cold Air Intake for TBI
Does anyone have the stock lower air intake housing for `88 Iroc 350 TPI? I need to get this project done. Thanks
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Best-
S-D
Best-
S-D
Car: 92 Camaro RS
Engine: 5.0 TBI
Hello 3rd Geners,
I am pretty much new to the forum and was wondering if anyone has tried this air intake setup I found on ebay? Will it even work with our TBI system.
By the way, My lady is a 92 Camaro RS 305 TBI completely stock. Just starting to look around for mods and would appreciate any and all advice.
Here is the link.
http://cgi.ebay.com/ebaymotors/88-95...rdZ1QQtcZphoto
Hope the link works.
Here is the link.
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
hehe nope, i tried that same one wen i had an RS, its for TBI trucks which obviously have a larger engine bay. the piece that sits on the throttle body is like 4 inches to tall
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 11, 2015 10:11 PM
