tbi,carb,or efi.what should i do.
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
hey all.
i'm planning doin a 383 swap.the motor i was looking at is rated at 450 carbed h/p.i have an 88 tbi formula.i am assuming that it would be easier and cheaper to switch it to a carb setup and still be emiss legal.it will be a street only car.i would like to switch it to an efi.just wandering what u guys think.thanx.--jay.
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
First question: Do you have emissions testing in yoru area?
Second question: Is it a visual inspection as well?
If the first answer is yes, and second is no - get a SuperRam. It still has an EGR, and you can use a lot of stock TPI hardware (sensors, etc.)
If the answers are yes and yes - start looking into prom burning unless CARB's were avaliable and considered legal for your car, because you're stuck with TBI as far as I know.
If both are no and no - get a converted LT1 intake, or HSR and have a lot of fun!
(Basically, avoid the carb if you can.)
Car: 1984 T/A WS6
Engine: L69 305
yeah i live in nj.and no no visual insp up top,just for cats.and i know for a fact that i can switch it over to a carb set up and be smog legal.thanx
Car: 1984 T/A WS6
Engine: L69 305
is there any complete tbi to efi kits?if so where can i find them.if not what will i have to buy besides the efi.i was looking at the holly one.
Car: 91 RS
Engine: 350 TBI
If the emissions is lax in your area and you want power for cheap, go carb. If you're worried about MPG then go with any aftermarket EFI. . .if you're worried about MPG and $$$, then stick with the TBI.
Car: 1984 T/A WS6
Engine: L69 305
GeneralIesrussi
Sep 3, 2015 03:23 AM
