What's this part called?
Old Aug 15, 2005 | 01:33 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey,
Whats the little adaptor piece called that goes into the hole by arrow in the intake below? The one that the coolant line is just stuck into and locked in place by a little plastic clip.
Does anyone know?
Mine broke right off today so I need to get a new one asap. Probably need to take off the d@mn intake to replace it too. Im f***king starting to hate this d@mn engine!
Ken
Old Aug 15, 2005 | 02:07 PM
JPrevost's Avatar
Car: 91 Red Sled
That is for the heater core. It's a good place to pick up the coolant for the heat, unlike the older carb intakes that make you take it from the front where the thermostat is.
Old Aug 15, 2005 | 05:28 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
That part is called an "intake manifold"
Old Aug 15, 2005 | 06:05 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Ok, I may be slow - but....
Again, Im trying to find the name, or ever better, part number for the piece of aluminum pipe/adaptor that goes in the threaded hole by the arrow on the intake. Mine broke so I need a new one.
I know what it is and what it does
Any help appreciated!
Ken
Old Aug 15, 2005 | 07:11 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
The following is from the GM B car (Caprice, Roadmaster) Parts & Illustration book for 91-96 model years, specifically from the LO3/LO5 engine page concerning heater hose hook up to the intake manifold (p 6-G25, in Group 8.000). It might not be the exact part you need (the book is for fullsize cars, you have a 3rdgen), but my guess is that it should work because the engines are very similar (TBI):
Fitting, heater hose
(1/2" - 14 NPTF with 5/8" nipple)
(1/2" - 14 x 1 and 23/32" long)
Group 8.866
GM part number 497853
used with a worm gear hose clamp
So the part you need is probably a brass hose fitting, with a barb on one end (for the heater hose) and pipe threads (National Pipe Thread) on the other end. You can also measure the old one that broke to verify the size.
You should be able to find one in Norway, but if you can't there's always
www.mcmaster.com
HTH (hope this helps).
EDIT: search for broken heater fitting or something similar and you'll find many other people like you have had the same problem.
Old Aug 15, 2005 | 07:26 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Thanks a lot for the great info, man!! I really appreciate it!
Ken
Old Aug 18, 2005 | 11:15 AM
3rdgenstm's Avatar
Car: ‘92 Z28
McMaster Carr is the greatest supply house in the world! If they don't have it, you don't need it.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
