tbi regulator bypass?
Old Sep 2, 2005 | 09:12 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
has anyone ever attempted to bypass the regulator on the tbi to use an external one...i have thought about trying it...(just for kicks) to see if it can be done..
Old Sep 3, 2005 | 07:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Use a 3/32" to 1/8" thick piece of steel, or 3/16" hard aluminum plate. Cut it in the shape of the casting where the FP can mounts to the TB. Can use the can as a template. Drill the four holes for mounting it. If steel paint it.
Use the original diaphragm (if in good condition) and cut the center out, leaving about a 1/4" wide perimeter. Bolt the plate onto the TB with the diaphragm as a gasket.
Use a bypass style regulator close to the TB on the return line. Several advantages to this setup: can use a monster size fuel pump and still have the regulator bypass the fuel at low loads. Easier access to adjust the fuel pressure. A good bypass regulator will hold a more consistent FP then the OEM one.
RBob.
Old Sep 3, 2005 | 09:18 AM
dwillis's Avatar
Axle/Gears: 3:08
thanks man...i will have more questions for you later...what kind of regulator?do you have a pic
Old Sep 3, 2005 | 08:58 PM
dwillis's Avatar
Axle/Gears: 3:08
why use the regulator on the return line and not the feed line?will that not let the full pressure of the fuel pump to the tbi?where can i get one of those regulators and how would i adapt a guage to it...thanks for your help man.i think i will try that if i can find the parts and the right line adapters...
junior419
Apr 7, 2025 11:35 AM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
lakeffect2
Sep 7, 2015 03:52 PM
