Gm Vafpr
Old Sep 15, 2005 | 10:41 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Gm Vafpr
The GM Vacuum Fuel Pressure Regulator ... hmmm ... ok I'm REALLY curious ... how is it even designed ? I mean I believe one can buy a regular adjustable one from GM ? But at the same time you can do it yourself
What did they do to the VAFPR ? Weld/braze a tiny tube .. and attach a vacuum line ? Is this something a machine shop (figured maybe one of my buddies could do it *lol*) or someone handy can do themselves ?
Yes I've searched.. I've read about them ... but like I said.. I'm really curious about how they're designed.
Old Sep 16, 2005 | 09:32 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
From what I understand it was originally used for marine applications.
Lon
Old Sep 16, 2005 | 09:54 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a tiny tube that comes out of it. You then run a vaccum line to a source on the TBI unit. I used the one that controls the thermac. Do you need pictures?
Old Sep 16, 2005 | 11:54 AM
lonsal's Avatar
This it a link to the Instruction Sheet I include with the special spring I sell for the VaFPR. It will answer your question regarding the source for the vacuum line.
Lon Salgren
Top-Down Solutions
Old Sep 16, 2005 | 02:42 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Alright
Old Sep 19, 2005 | 04:03 PM
Ronny's Avatar
marine applications is what i heard. keep in mind marine power is somewhat linear. the tune has to be so much easier to develop. no shifting(in my rig anyway). not much on off on throttle. i suspect it (vafpr) was an attempt to use TBI on a larger CID(over 350 cid).
Old Sep 19, 2005 | 05:11 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
GM includes the VAFPR with their HT502 crate engine. It allows them to make some good power out of the older 454 TBI setup.
fadetoblack
Jul 24, 2006 12:02 PM
TBITrucker
May 12, 2006 09:57 AM
seanof30306
Nov 8, 2003 01:37 PM
Gunny Highway
Sep 18, 2003 10:07 AM
TonyC
Jun 15, 2003 05:34 PM
