Dual Snorkel Air cleaner with sensors
Car: 91 Camaro RS
Engine: 305 tbi
anyone know where i can buy a dual snorkel air cleaner for my 91 rs camaro, i cant find one with the sensors that are in the factory, one and i was going to just go out and buy an open element but im not sure if those sensors are necessary, thanks alot
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I bought a dual snorkel air cleaner and removed the sensors...i didn't really need them...if you decided to go with an open element, them you would't have any sensor there anyhow, so you really don't need them with the dual snorkel...also, you might look on ebay for one, the ones that are in nice condition usually run around $120.00-$150.00
The 2-wire sensor in the base of a stock TBI air cleaner is the IAT (Intake Air Temp) sensor. Don't just unplug it. ECM needs that information to help run the engine properly. Reinstall it in whatever dual-snorkel you buy (It's a pretty simple drilling operation). If using an open element at least put the sensor somewhere near the filter element so it car read the temp of the air going into the air filter.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Welcome to TGO!! If you use the
function (located at the top right) you will find a gazillion posts about the dual snorkel air cleaner. I'm so confident you will find it, I'm going to close this thread to cut down on redundant posts...
Bruce (90RS305)
function (located at the top right) you will find a gazillion posts about the dual snorkel air cleaner. I'm so confident you will find it, I'm going to close this thread to cut down on redundant posts...Bruce (90RS305)
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
