how do i put a tbi on a supercharger?
Old Sep 29, 2005 | 12:28 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
eventualy i would like to put a super on my car,but i would also like to keep the tbi.
how would i get the tbi to work with it?
Old Sep 29, 2005 | 05:44 PM
redcamaro1989's Avatar
Car: 1989 rs RIP, 96 grand marquis, 92rs
Engine: LO3, 4.6l, L03
Transmission: 700r4, AODE,700r4
Axle/Gears: 2.73, 3.08, 2.73
as for as i know it is impossable. i have never heard or seen one for a tbi. i am pretty sure you would have to go with tune port.
Old Sep 29, 2005 | 11:35 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
After doing alittle research, you dont need to go with a tune port to put a supercharger on a tbi. WhippleSupercharger make superchargers for GM 1989-1995 5.0/5.7 TBI engines. Heres there linkWhippleSuperchargers Check it out
Old Sep 30, 2005 | 11:14 PM
92ss wagon's Avatar
Car: Caprice wagon
Engine: 5.7TBI
theres a whipple on Ebay right now for the TBI. Comes with TBI intake, rollers and a bunch of goodies too
Old Sep 30, 2005 | 11:32 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Wow that's sweet, I think I might buy that kit!
Old Oct 1, 2005 | 01:33 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I built a weiand supercharged 310 that ran a 12.9 @ 107.8 shifting at 4,500 rpm. 3.73 gears and a T-56 though. The dyno numbers were right at 300 RWHP @ 4,500 and 365 ft/lbs @ 3,000 in 4th gear. Lightly worked over 193 swirl ports and the stock vortec/B-body LT1 cam.
https://www.thirdgen.org/techbb2/sho...hreadid=323219
Old Oct 1, 2005 | 08:49 AM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I wanted to do the same thing...something I'm thinking about (give it some thought) is the universal carbureted small block supercharger kit from Vortech. It could probably work with little to no modification.
Just a thought.......
Old Oct 1, 2005 | 11:51 AM
jimp2001's Avatar
Engine: LO3 305 TBI
If you're gonna go that rute, it's easier to throw a carb on top and call it a day. With that setup, you have no provisions for your factory connections, EGR, brackets, etc.
That's what makes me VERY interested in this TBI S/C setup
Old Oct 1, 2005 | 01:08 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Weiand makes a 50 state legal version of the 142 complete with EGR valve for both the carbed and TBI SBC. The difference is the intake and a carb-tbi adapter.
Old Oct 1, 2005 | 02:26 PM
92ss wagon's Avatar
Car: Caprice wagon
Engine: 5.7TBI
WHIPPLE SUPERCHARGER AND PARTS FOR TBI SETUP FOR 87-95
Link for an auction Wish I had the money
Old Oct 1, 2005 | 02:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
This is a 2.8 I found on the internet, but you get the idea.
Old Oct 1, 2005 | 02:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My Weiand from Ebay. $700.00 shipped.
Old Oct 1, 2005 | 11:42 PM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
Hows the hood clearance with the weiand kit, looks like a close fit.. due to the fact you have to put the tbi unit on top of the weiand supercharger where as the whipple supercharger is not on top of the charger.... I would go with the whipple since iv had some experience with whipple and they are good super charge system...
Old Oct 2, 2005 | 12:21 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My blower is not going in a F-body it is going in a G20.
The RS that has an identical blower on it had a 4" cowl hood on it to make room.
The blower will fit under the stock engine cover on the G20. The TBI is almost 1.5" shorter than a carb and the adapter is only about 1" tall.
This is a carbed supercharged 434 I saw on ebay a while back.
Attached Thumbnails how do i put a tbi on a supercharger?-supercharged-434.jpg
Old Oct 15, 2005 | 06:42 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
wow thats a tempting package. Fast355 thats really good numbers. Youd even give my ls1 a run for the money. whats the package cost new?
Old Feb 1, 2006 | 04:48 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
700 for that kit sounds like a great deal.
Old Feb 2, 2006 | 12:49 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
How about using the carb supercharger and getting the adapter plate for TBI. Than use the weiand chip.
It should work!
I mean whipple chip!
Old Jun 3, 2007 | 05:26 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: how do i put a tbi on a supercharger?
Does this mean it will bolt up to the 87 and up centerbolt heads?
Old Jun 4, 2007 | 02:14 PM
Dual TBI's Avatar
I worked on a truck with a Whipple SC once and there is one thing you need to watch out for. We had problems with the engine not getting enough fuel on acceleration. If we added enough Acceleration Enrichment, the problem would lessen, but then we had a post acceleration bog and black smoke out the exhaust pipe until the engine cleared all of the extra fuel out of the intake. The folks at Whipple told us this was something they know about and have seen and recommended that an Edelbrock port injection TBI intake be used. We suspected and were told by Whipple that the problem was caused by the much greater lag time of the fuel getting to the heads (relative to the air) because it has to travel through the supercharger. We tried the Edelbrock port injection kit and it worked, but that cost was quite a bit more than the original expectation.
We also had a truck with a Pro-Charger and had better success. It blows the air through the TBI unit and I suspect is the reason that a "normal" acceleration enrichment worked with it. If I had to choose, the Pro Charger (if they still make it) would be much easier to make work with minimal tuning.
Just another man's opinion...
MustangBeater20
Oct 29, 2022 09:20 PM
toronto formula
Nov 10, 2015 06:17 AM
PestilenceIV
Aug 20, 2015 03:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
