can u guys help w/ this problem?
Old Oct 3, 2005 | 03:17 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
i know this dosent go here and i tried getting help in the electronics board but im gettin no answers over there and u guys always seem to help me out if you could take a look at this and tell me what u think
https://www.thirdgen.org/techbb2/sho...hreadid=324064
Old Oct 6, 2005 | 12:29 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
yes i think i can help you out. all you need is the switch and some wire. the fan relay you have has a dark green wire white stripe (not sure thats the wire hanes manual says, ill look at my car tomarrow0. tap into that wire and run it to your switch. wire switch to ground and you done. if its a lighted switch it wont light, but it works.
hope this helps.
Old Oct 6, 2005 | 11:04 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
https://www.thirdgen.org/newdesign/tech/cool.shtml
This should fix you up
Also there is a section on this board for cooling systems
Old Oct 7, 2005 | 12:29 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
ok so i looked at the relay on my car. the activation wire is green with white strip. this is the wire that goes to the fan switch on your head. if you tap into this wire and attach it to ground through the switch. this is how i have it on my car. it allows you to turn the fan on by the switch or if you leave the switch off it will work normal
Old Oct 7, 2005 | 12:14 PM
Engine: 305 tbi l03
beautiful so i wire one hot to the switch one hot to the fan relay and one ground to the switch? cause theres three terminals i belive although im at work and not exactly positive....thanks for all the help though ill get to work on that this weekend when i try and wire up this tach. and as for the cooling board next time i will post there i was just torn because this deals w/ wiring up somethin so i wasnt sure which one would be better
Old Oct 8, 2005 | 01:42 AM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
the one green wire is hot so you dont need to run a hot wire. just tap into the green one and run that wire to your switch. Then from the other terminal of the switch to ground. you can use a lighted switch but you wont beable to get it to light because your not on the positive side of the circuit.
pjsparts
Oct 29, 2025 06:39 PM
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
